Progress this week. First thing was I found a used rd105 arb air locker for a super 35. The spider gears need replaced and the shafts it came with are the alloy brand which arnt the same chromoly as the revolution so the spot where the bearing rides is pretty worn down on one side so I will prob keep those as just a back up. Still for the price it was cheaper to get this than buying a new one. When money allows I’ll be buying a front arb and compressor when they go on sale together and re gearing to 5.13 as I am stock 4.10 now. Super exited to be locked and regear but it’s a lot of money I don’t have since my wife and I are trying to save to buy her a car. Secondly after installing my transmission rear main seal and taking the driveshafts out I noticed the front shaft had a ton of play. It’s my fault too bc my stock front one I rebuilt with spicer joints were greasable and had the grease fittings on the end caps but that wouldn’t fit with the snap rings so highschool me just ended up taking the fittings off so I just had holes right into the caps. It is what it is so I figured this was a great time to get a Tom woods, especially after reading the 33vs35s thread a few weeks back lol. I also thought this would be a good time to swap back to a genuine mopar transmission mount as this past summer I tried a ucf low pro mount in hopes to go to a 1in deep skid before a body mount lift but it was just too much for a daily so I swapped back to stock ( $15 anchor brand mount ) and it still wasn’t as great as I remembered but lived with it till now where temps are much colder and that anchor rubber it rock hard. So new front drive shaft and the mopar mount, it’s a world of a difference better and working great for 4wd now that snow has been coming down almost every day here in eastern idaho.
Things to work on next are my cheap Amazon halo headlights have been giving me problems so it’s time to swap them with truck light Amazon knock offs and get away from the halo ring as well as the clock spring since my airbag light is on and my horn doesn’t work. Also forgot my cheap door handles have given me problems where the lever for the handle it’s self has inverted over the pin to open the door from the outside and I ended up just smashing the lever further down to prevent that as well as the door latch actuator assembly that all the rods connect to broke for the outside latch so I has to use tie wire to tie the rod to the lever on the assembly. It’s opens now but I’ll be replacing the door handles with some that have a better design lever soon just to make sure it doesn’t happen. Wife and I also got out and chopped our Christmas tree this past weekend with no front drive shaft in.
Another side note that doesn’t involve the jeep but my personal skills is my friends fzj80 didn’t have 3rd row seats when he bought it but really wanted some. So after buying some seating that didn’t have brackets and we’re never to be seen to purchase oem brackets or even get photos, we decided to just build a super easy bracket. We designed, built, and installed it in 1.5 days which I thought was pretty good as well as the cost was 55 bucks. I basically designed the whole thing so it’s ok to critique it but I didn’t weld it together. It was a lot of since it got us the confidence to maybe build me a tire carrier soon.
