I've searched through and haven't been able to find someone with the same issues I've got.
2006 X, 42RLE, ~150k miles, 35s, 4.88s, correct speedo gear.
Issue I'm having: the Jeep sat for a few weeks. Went for a drive and it flared on the 1-2 shift, then dropped hard into 2nd, and went into limp mode (stuck in 2nd gear) and check engine light came on. Checked the fluid, level was correct, not burnt. Pulled the codes, had P0731 and (gear 1 incorrect ratio). Cleared the codes, drove it again, same issue. Worth noting, it will do this even with the shifter in 1st.
Did a little searching, found the solenoid pack is prone to failure on these, got a solenoid pack kit off Amazon (mistake, I know), replaced it, then had the same issue, same codes, however with an additional code specific to the shift solenoid. Transmission input and output speed sensors were both replaced at this time.
Took the Amazon solenoid pack out, returned it, ordered a new kit with a Mopar solenoid and filter. Test drive, same issue as originally, but no solenoid code. Still has the P0731.
This is a different shifting issue than the TCM related hard 1-2 shift issue. I've been living with that issue by just periodically clear the computer with a scanner and it goes back to normal for a while.
My question is, does this sound like a TCM issue, torque converter issue, or am I looking at a rebuild/replacement of the transmission at this point? I'm very mechanically inclined, with the exception of automatic transmission work. If it is indeed in need of a rebuild, I'll probably end up buying a built transmission from somewhere like ATS and swapping out myself.
Sorry for the long post, and thanks in advance for the help.
