So my 2005 TJ has an aftermarket alloy radiator and a separate trans cooler and I'm about to install a trans temperature gauge. I would like to know which of the oil lines on the 42rle comes straight from the torque converter or in other words which is the output for the ATF fluid. I have read in several posts/forums that the drivers side on the radiator is the output from the transmission and that the passenger side is the return to the transmission. Being the car doesn't have the standard radiator though this doesn't help me, hopefully someone here can spread some light.
