Could use some help please
2006 LJ 137k miles. 42RLE Repaired normal stuff ( fuel pump, catalytics, a/c compressor and all lines). But, this week trans gets “stuck” in second and will overheat and go into limp home. Now, if I force it in first by shifting or I have stopped completely and then stomped it causing it to get into first, it will behave itself and downshift properly. Seems to happen in the first minute after starting. I have just dropped trans pan and changed filter. Replaced about 5 qts. I know this isn’t a true flush but I didn’t have the tool to undo the hose that goes into the trans cooler at the radiator. I’m afraid I need an official rebuild or buy reman and replace. So would a true flush help? Or anything else I can do that my help. I read these forums all the time and this is the first time I have posted so if it is a sorry post I’m sorry but I don’t have 2 grand today to fix it.
