42RLE Transmission Pan w/Drain Plug
G-Whiz
Hayward, CA, United States
While I'm under the vehicle the next couple of weeks, I thought I'd change out the filter and fluid on the tranny and while Im at it, change the pan to one with a drain plug.
Also was contemplating getting a deep dish, but not sure how it would impact the skid...
Anybody have any preference on what they have used?
There's a transmission filter above the pan, just draining the fluid without removing the pan to replace that filter would be a bad idea.
For that reason, there's no reason to pay more to get a pan with a drain plug in it.
Reactions: Michael Roberson
wanted to run an temp gauge for the tranny and install a temp sensor in the drain plug hole.
Other than that; a drain plug just makes life easier draining the tranny.....
G-Whiz, sorry to bring back an old post but did you ever find a good pan with a drain plug?
Jerry, Where did you install your sensor if not in the tranny pan?
