These new LED headlights are amazingly bright and a huge improvement over the Wagner sealed beams I had before. I am experiencing a couple of issues however:
1. When the brights are turned on, the 4WD light also comes on (Jeep is not in 4WD).
2. When the brights are turned off, the bright indicator has a bit of a delay (~2 seconds) when going out, not instantly off like with the Wagners. The bright lights themselves turn off immediately, as demonstrated in the video. It's also interesting that when I use the 'flash to pass' feature, the bright light indicator goes out instantly after releasing the lever.
These LEDs installed perfectly, no adapters needed, and I had no problems other than what I mentioned above.
A note on my 4WD light...it's always on (even when not in 4WD). I think this is due to the 241 transfer case swap and a new switch never being installed.
Hopefully the video will do a better job explaining than I can. Any ideas?
