I have a 93 YJ that has parts of the drivetrain from a 2000 TJ in it (engine, transmission, transfer case,). Going from a 12vdc to the 5vdc ECM system was quite time consuming. The last thing I have on my plate is getting the 4wd indicator and front axel vacuum modulator to work properly (My 93 has a vacuum modulator for the 4wd axel disconnect with an electrical switch to indicate it is engaged). The 93 used intake manifold vacuum that went to a vacuum switch on the transfer case to port to the front axel modulator to engage/disengage 4wd. My plan is to install two solenoid valves running off the TJ transfer case switch and use vacuum through them to shift the modulator. Then I'll use the front axel switch to indicate 4wd on the dashboard instead of the transfer case switch.
I've wired in a single 3-way solenoid thus far but it traps the vacuum in the line when the solenoid changes state, thus not allowing the modulator to shift. I can vent it by adding in another 3-way solenoid. I don't know if the Mopar 05083138AA switch can handle 2 to 4 amps across the contacts from both solenoids. It's doing okay with the one solenoid of 1 to 2 amps now. Anyway that the amperage specification rating of the switch can be found ? Prior to my rewiring the only thing the transfer case switch did was light the dash light of a few milliamps. I can fire a small relay off the transfer case switch and use it's contacts to drive the solenoids. I'm trying to avoid that. This Jeep has a wiring system of unique complexity design already.
