I'm actually going with the 5.2 swap myself. Personally having the ECU to communicate with everything makes it better for me. I'm not crazy about having too much power, but the V8 will definitely pull way more than the straight 6 and be close to the same weight or lighter(if I splurge on used aluminum heads) I want something naturally aspirated, that has more power and torque than stock and be as reliable as the stocker. I will keep the 5spd as well.
Are you adding roller rockers to go along with the aluminum heads? Are you keeping the stock intake? If you are did you update the plenum gasket? Make sure you do if you're keeping the stock intake. And bump up to a 52/53mm throttle body.
A tune for sure. Still waiting for a discount on the HPtuners stuff but who knows.The larger TB will help it breathe even at the lower RPM's. Yes the shave kit does seem to help the lower RPM better. Get a TORQUE cam and you can get some ok numbers. Get a Crane cam or one from HIPoTek and then get a tune from Flyin Ryan Performance or Hemifever. Even a stock engine will benefit a tune for either guy.
It's to bad they don't make the EQ heads anymore. They flowed better than stock and cost under $1K.
Since the cam has to be replaced on the donor motor, as long as compression and everything else is good, a torquer cam was an option, or the roller lifters with the higher ration and stock cam parts.
I strongly recommend an LS motor. You can pick either aluminum or cast iron block.
I have access to both motors and transmissions. Which is best? Which is easiest? I have a 99 TJ with the 2.5l? I know there is a ton of info out there on kits and how to convert....I am trying to decide which path to take. Any advice is appreciated. I will be doing this swap sometime on 2021.
Because I find it better in many other applications not just Jeeps. Yes I do have an LS in my Jeep and have less problems than a friends Jeep with a Hemi.Nothing against the GM engines but WHY?? Don't just say that and leave it with an open ended statement.
I can list the reasons why the Dodge engine is a better BUDGET swap. And if you put some work into your magnum engine you can get some pretty good numbers from them. So why use a GM engine?
I apologize if I upset you.
It's not expensive per say, I am just cheap. lolHow much does the HPtuners stuff cost?
You can find the SCT 9550 tuner for pretty cheap now. Here is one on Ebay for $250 and then just get the tunes for either guy.
SCT Handheld Flash Tuner Vehicle PCM Flash tool | eBay
Just the tunes from Hemifever are $200 and they are getting $399 for the hand held tuner.
If you get aftermarket heads and go to 3/8" studs you can use Chevy rockers also instead of just Mopar. I have Scorpion RR's for my engine.
You want to match your TB to the amount of mods you are doing. It's like over carbureting a old school engine.
I had a 52mm TB on mine with stock cam stock ratio RR & headers.
Also get the Patriot block huggers and not the Summit ones. And think about paying that little extra for ceramic coating since it will cut down on the heat. These engines produce a lot of heat.
