Try it now. Had to trim it down a little.
Cool..
You have an awesome looking shop/garage there...
Loaded back up and hitting the road at 8am to get tuned. The plan at this point is to get dropped off and drive it home. I’ll get some pictures of the oil filter mount for you.Any updates.??
Also wanted to know if you could get a few pictures of your remote oil filter mount where and how it's mounted. Somewhat limited on the space under the motor for sure.
Thanks in advance...
356/377. Was hoping for closer to 400 but after the drive home and even in the pouring rain, I don’t care at all!!! It feels great going down the interstate at 70 turning about 2300 and still having tons of pedal left. He really didn’t have to do too much on the dyno. The tune in it was used for an automatic they had just finished up. So when you put the clutch in, the RPMs would either hold or climb really quickly. Once he changed that he didn’t have much else to do. Just make sure everything looked good across the board and it did. It does still hold for just about a second at the RPM you put the clutch in, but I don’t mind it. The AX15 will take some getting used to for sure. Caught myself more than once about to change to 6th gear. But cruising at 70 in 5th and rolling into it feels great. I’ll put a few hundred miles on everything before I start getting into it too hard. The only thing I’ll need to address sooner rather than later it the exhaust. It’s a little “drony” inside. 3.5 inch single exit with no cat. First thing I’ll try is a high flow cat but I don’t think it’ll help much if any. I’ll try a couple different mufflers and see what works best. We’ve got a Valvtronics muffler at the shop I may try just so I can flip over to open headers if I ever wanted to. But all in all it’s way better than I could have hoped for.Be sure to get a video of at least one pull on the dyno. Looking forward to seeing it, and the results.
Wow that is awesome. I'd be happy with numbers like that. I'll bet it feels great driving too.
Almost like it 3x the power at the wheels as it did!
Really nice.!!
Nearly impossible to describe the difference between before and after, isn't it..?? It's almost like mind overload. I really do laugh every time I stand on it, between the crazy acceleration and the beastly sound. After driving so many of these for so long and knowing exactly how they drive.
Like you said, the old "Keister Dyno" says it's at least 3 times the power now..!!! (And those never lie)
That first tank of go juice seems to evaporate very quickly. I don't really know what caused that, maybe I left the gas cap off..
