$8.50 recovery rings
As you know, it's nearly (if not completely) impossible to keep 100% of people from using a product the wrong way. I'm not sure I can picture why anyone would, but I can picture somebody running two ropes through the center of one of these and using it like a shackle.
My concern with the price has more to do with what kind of coating or surface issues might present themselves where it rubs on rope, something I might not have even thought about except for your Warn fairlead theead. Then Mac commented about it feeling more grainy than his other ones.
That's the equivalent of expecting Warn to warranty a winch that was snatched against. Regardless, the WLL for any scenario is still bullshit. If it even more bullshit if we don't know the safety factor that the WLL is derived from.
The notable feature of the Factor 55 ones is rubber or silicone teeth that hold the rope in the ring.
Just not worth the cash IMHO.
Can be quite a PIA rigging up four plus pulleys/rings and getting everything set right.
-Mac
Not the deal that the $8 rings are, but could this be a reasonable priced alternative to the Factor 55 ring?
https://www.amazon.com/Retention-Pulley-33000lbs-Recovery-Shackle/dp/B0CZMF1QN1/?tag=wranglerorg-20
Or to a slightly lessor degree, even this:
https://www.amazon.com/dp/B0DG2CCR6B/?tag=wranglerorg-20
Reactions: macleanflood
Reactions: Murf926
Do you think those silicone ticklers are stiff enough to do what they claim to do without also tearing up the rope?
Dunno. All speculation until someone pushes a penguin off the cliff into the water below to see if they get eaten by a polar bear.
Something tells me synthetic winch line is tougher than silicon.
-Mac
-Mac
Which brings us right back to the question of wether or not these ticklers actually do anything. Can you offer any critical thoughts or do we just accept everything at face value?
Good questions. I don't know.
I guess the only way to tell for sure would be to test these two along with a Factor 55 ring and see what they all do. Too rich for my blood though.
I'll stick with my old TRE aluminum pulley. It works better than these rings do. And I won't buy anything from Factor 55.
Totally agree...but not all of have the luxury of spending $100+ on a piece of recovery gear that most of us won't use until you really need it.
I'd love to find cheap affordable stuff, that while perhaps not robust enough for say day to day professional towing, is good enough to throw in a recovery bag for those oh shit moments.
Guess I need to order a couple and see if they work.
Again...big fan of rings...after cooking a couple or three winch motors rings do two simple things...one...they make you run more rope off the line thus increasing the power of your pull getting you down to that first, or second rope layer...and two...they double the pulling power (or whatever multiplier times rings used.)
That and for occasions when pulling heavier vehicles you can run the pulleys anchored off a tree or rock, or redirect winch lines. All useful things.
-Mac
-Mac
My argument is that I have done enough rigging to recognize the dangers of vehicle recovery; which then necessitates that my recovery gear be safe, reliable, and have as few gimmicks as I can recognize. A rope pulley without a bearing is a gimmick. And I have used these rings enough to be irritated by them flopping around during setup. Silicone fingers are not enough to fix that.
iirc they net 1.6x, not counting the benefits from pulling more line.
In addition to better leverage, there are advantages to keeping the motor turning faster. Motors are typically less efficient (produce more heat) and produce less torque at very low rpm.
