So I was working on my girlfriends 97 auto 4.0 TJ because of some issues when alignment. Specs are 4 inch lift, fully adjustable control arms (no idea the brand), adjustable front track bar, Slip yoke, Ford 8.8 in the rear) PO would wheel it, but my girl friend is looking to use it for a daily more then anything.
This weekend I decided to do a driveway alignment to dial in the toe and straighten out her steering wheel. I noticed some bump steering and thought to start there. As I was working on the toe I noticed that the angles of the drag link and Track bar seem to be off.
It looks like PO put a dropped pitman arm on it and has thrown off the angles (I'll post a picture and hopefully someone can confirm for me).
I decided while I was down there to check on the caster since on the highway it seems to be all over the place.
I used the level on my phone and placed it along the front driveshaft and also along the front diff (see photo for where I placed the phone for measurement) and got -8 degrees of caster!
I've never checked caster before so maybe I did it wrong but what from I read online the Jeep is having all the symptoms of caster being off I just didn't think it was that far off. I believe caster should be between 6-8 degrees so at -8 that's just crazy. Until I can get it to an actual 4x4 shop for an alignment should I just adjust the uppers on my own for the time being?
Long story short:
Should I go to stock pitman arm from what I believe is a dropped?
Did I measure the caster angles in the correct spots and if so, should I adjust front upper CA to bring the caster back between 6-8 degrees?
Long story short:
