1992 Wrangler base 4.0 five speed. DRL's not turning off. I have removed the firewall relay, no help. Removed fuse block fuse, no help. Removed both at the same time, no help. Replaced switch, no help. Is there a color coded wire to cut/splice to put in a switch for on/off use. There is not a disconnect om the drivers side firewall as on other year models. Right now I am plugging in the new switch for night driving use. I don't mind if the DRL's work, not a priority. Thanks for any advice if anyone has also had this problem. Because wiring for model years differ suggestions for 1992 year specific would be great.
