It’s a 97 2.5l 5 speed. Been sitting a long while and just recently got it going with new parts.
Clutch
Alternator
Battery
Plugs and wires
Cap and rotor
Fuel tank
Starter
Problem is that it will start and idle just fine, most times It will rev out without any hesitation sitting in neutral. But as soon as I put it in gear and try to drive it, it wants to die with any throttle input. Occasionally it does this before putting it in gear but not often. No CEL at any point, had it on a scan tool but didn’t show any codes. Also cleaned the throttle body. Haven’t seen any wiring issues or vacuum leaks so far. Not real sure where to go from here, trying to avoid just throwing new sensors at it.
Clutch
Alternator
Battery
Plugs and wires
Cap and rotor
Fuel tank
Starter
