I have a 1997 jeep wrangler tj. Just recently it has been stalling on me. No sensor lights. Plenty of fluids. When i try to restart it and give it some gas it stalls again. Any help would be appreciated
Start with the simple stuff.. air filter, check your fuel lines for leaks, gas cap, and whatever the last thing you did to it recently maybe you put it back together wrong or bumped something
I’m not a 4.0 wizard, but is it stalling suddenly or more of a couple misses and then a stall? The first would lead me to believe ignition system, plugs, coils, maybe grounding out at the boot, etc. Or if it’s slower I would check fuel, maybe injectors or pump or something. Not much help I know, but it’s what I leaned when working with older vw engines.
