Gives me food for thought. Thanks, Chief.I had carpal tunnel surgery 19 years ago. Suffered with it for 5 years, which I had done it sooner, instant relief. It got so bad, it was going from my hand all the way up my arm.
Precisely. I bought a brand new Millermatic 211 that I've yet to have a chance to use. I bought it when I realized that most of my project vehicles will involve some form of rust repair, and I'm too cheap to take 'em to a shop.
Thanks for the well wishes, my friend. I hope the same for you. I have heard a lot of stories of successful surgeries for this type of stuff, so that's encouraging.I have carpal tunnel in both my hands, along with what they call "unknown soft tissue damage". I can't clean my glasses without my hand hurting like a son of a bitch. I go for a nerve study in October for them to see if they think surgery will help me or not. My father had the surgery done on both hands, and it made a world of difference for him.
Really hope you both feel better soon buddy! Glad your wife is heeding her doctors advice. I know I have great difficulties doing that, lol.
I have a real nice one that I bought probably fifteen years ago. It was made in the same area of upstate New York where I am originally from. I've used it quite a bit throughout the years.Sandblaster is a great investment if you can afford one!
Nice work. It's amazing how many hours can be consumed y even the simplest of jobs.Had an opportunity to work a bit on removing one of the two broken upper bolts from the rear shock area. Drilled a hole through the center of the bolt so I could collapse it in on itself somewhat, thereby breaking it loose. Having the tub raised above the frame really makes it nicer to work in there (along with no axle, exhaust, or gas tank!). Still, it was a three-hour endeavor just for the one bolt. However, it was completely successful, and I now feel encouraged enough to tackle the other one in the same manner.
View attachment 110585View attachment 110586View attachment 110587View attachment 110588
Did it end up threading down through or did you pull it back up the way it was started?Had an opportunity to work a bit on removing one of the two broken upper bolts from the rear shock area. Drilled a hole through the center of the bolt so I could collapse it in on itself somewhat, thereby breaking it loose. Having the tub raised above the frame really makes it nicer to work in there (along with no axle, exhaust, or gas tank!). Still, it was a three-hour endeavor just for the one bolt. However, it was completely successful, and I now feel encouraged enough to tackle the other one in the same manner.
I had to back it out the same direction as when it broke (counterclockwise from underneath). I tried the other direction, but the bolt had twisted itself just above the break, and it wouldn't pass through. There was about .250" of threads exposed below the nut, which placed the end of the busted bolt right about level with the cross member. Enough to see the exposed threads, but not enough to grab hold of with Vice Grips. I had to grab hold of the top of the bolt that was protruding through, and twist from that position. That's also the area that I collapsed with the Vice Grips to break the bolt loose. It was a bugger of a job, that's for sure. As @Fouledplugs said, very time consuming for such a simple job.Did it end up threading down through or did you pull it back up the way it was started?
Thanks, @jjvw. I agree, and additional strength was not truly something I was concerned with. Hell, what I have would probably be fine, but there's just that nagging feeling that I ought to just take care of it now, and remove all doubt.Whichever you pick, the cheaper one is probably fine. There is no need for extra strength or bulk over the stock spring seats. I reused mine when I relocated the springs.
Artec makes one too.Thanks, @ac_...
I actually remember reading that thread before. I'm seriously considering ordering either the Rokmen kit, or the one from Ballistic Fabrication.
I took a look at those, but couldn't help but wonder if those enormous side plates wouldn't hit on the frame-side track bar mount. They seem to be more style than structure, and the passenger side one would have to be trimmed to clear the TB mount, I suspect. That is, unless you were keeping the perches in basically the stock location. They might be fine, if that's the case. You'll have to let us know how it goes for you when you do yours.Artec makes one too.
Its the one I have, but have yet to burn in.
https://www.google.com/amp/s/www.artecindustries.com/TJ_rear_coil?amp=1
