Afternoon gents,
I know this topic has been discussed, and I have read through them but I have some symptoms to go along with it that I have not seen mentioned yet.
As stated in the title, I am having code P0304 (cyl. 4 misfire)
along with some intermittent RPM gremlins. Bear with me now as i try to explain this. Intermittently, The rpms want to hang at about 2k, or sometimes incrementally higher before slowly coming down, as if i have the pedal pushed down, or it is somehow getting more fuel. This has been going on a few months now, but i was under the impression it was me missing shift points. (manual trans.) but it also rises high sometimes on a slight tap of the gas, as if i was trying to rev it up.
Recently, when coming to a stop SOMETIMES the rpms will go way down to the first mark on the gauge, and then kinda find itself and return to normal..either that, or I tap the gas to get it to go back, whichever happens first. It seems to idle ok otherwise, just slightly rough.
Last weekend i got code P0171 (if i remember correctly) which was for upstream O2 sensor. I replaced that with the proper NTG sensor, along with AutoLite AP985 plugs, with new wires and the CEL went away for a few days. The new code, P0304 showed up this morning.
Spark plug #4 looks new still, slight discoloration from heat but looks the same as all the others. they're brand new so wear is extremely minimal. wires are set on good, triple checked. cap and rotor seemed fine, although i may grab a new set and see if that helps. I am going to rent a noid light today and check for a pulse in all injector plugs and verify that is okay along with volts with a multimeter. if that checks out I will pull the fuel rail and check that all injectors are spraying properly (spray pattern/fuel amounts)
If those tests come back good, I will then perform a cylinder leak down test (never done it before) and see what i come up with.
Am I missing anything? Do you guys have any thoughts or additional comments, or other factors i should be considering?
Again, i know this topic has a lot of threads, but I wanted to double check through yall with the accompanied symptoms I am having.
Thank you in advance.
