i have a 98tj, 4'' currie mid arm kit, with bump steer.... i know theres a ton of threads and i have read them all! just looking for secific advice on MY setup. thanks!
i believe the drop bracket for the adjustable trac bar is my issue but i would like help as i don't want to go shotgunning parts to fix the issue.
the image obviously is not my jeep but the measurements ARE for my current set up on my rig.
My concern is a drop pitman arm will not realign my steering geometry to where it should be. Would a tie rod flip kit installed on ONLY the passenger upper help bring my geometry back to spec or is that a bad idea?
any help suggestions would be greatly appreciated. can take pictures of my actual setup later tonight if that helps
factory pitman arm
rough country adj trac bar with mount bracket
factory pitman arm
