1998 TJ that recently had a very dead battery. It would start and run (albeit a bit rich) just fine with a jump. When it was revved a bit or after a while of charging the gauge cluster would come back to life. After the latest jump it hasn't woken up. The battery itself has been replaced with a brand new one, charging/holding the charge fine (alternator is fine), but the gauges are dead. We pulled the gauge cluster and found that the pins for both constant and ignition switched power are both dead.
So the gauges themselves might be fine?
Anything else we can look at?
What "feeds" the gauges? The ECM? If so wouldn't it have issues starting running?
The whole dash is apart. No codes at all from the OBDII reader. Gauge cluster doesn't respond to self test at all.
Tried to manually give power (and ground) to C2 plug pins to see if the gauges did anything, but not sure that's actually a test of anything.
Questions:
- Power at fuse 10 (Labeled instrument cluster) inside block with ignition on
- No power at fuse 17, inside block, key on or off
- Gauge cluster's C2 blue plug pin 8 switched power is dead, pin 9 constant dead
- Under hood light and courtesy lights have power (apparently they are on the fuse 17 circuit)
Questions:
- Why is there no power to the gauge cluster (needles, etc) when fuse 10 seems fine and is fuse 17 involved at all?
- IF fuse 17 was the source of C2 pin 8 (switched) or C2 pin 9 (constant) and its dead at the fuse box, then why are both pins dead at the C2 plug?
