98 Wrangler TJ wheel spacers
somis81
Ventura CA
After a 2" lift, I have a rub on full Steering turn on the front tires.
Can I just put the spacers on the front wheels or do I need to put them on all 4 wheels?
Add 2 small washers here on both sides.
A suspension lift moves the axle to the side so if your front tires are rubbing on just one side it's like caused by that issue. I just made a post at https://wranglertjforum.com/threads/how-can-i-fix-my-front-axle-being-off-center.37521/#post-621646 that explains how and why.
What size tires are you running and are they on the stock factory wheels? And is just one tire rubbing at full turn-lock or are both front tires rubbing?
30 x 9.50 r15 on stock factory wheels.
Both tires were rubbing at full turn-lock.
Tried 2 washers and its good now.
I stood in front of the jeep with both front tires straight forward and looking down from outside of the fenders to the wheels, it look as as though the front driver side tire is showing about a 3/4" to 1" more than the passengers side tire
