Hi all been surfing the forums for weeks and havent seen this issue. This is a new jeep to me. The transfercase was replaced before i got it. I have a 99 tj 4.0 89k miles with a pretty heavy trans leak. It also shifts weird in reverse and I assume there related. When I put it in reverse I can feel the trans engage immediately but it won't move at first. After a few minutes it moves just fine no issues. It drives fine in forward. I cleaned it up and found that It looked like the leak was comming from the adapter so I replace the seals. I also replaced the pan and seals and filter because the pan was pretty dented up. It stopped leaking for a week then started up again just as bad. I was thinking the torque converter was bad thinking it would explain the slow engaging of reverse but it's not leaking from there it's from the adapter. Any ideas I'm stumped?
