Welcome to the forum neighbor, Martinez.Anti-oh. Work in Pleasant Hill.
I am following up on my earlier question regarding my 2006 LJ. Am in the process of ordering the Rancho RS5000X shocks (55239 & 55241) and Pro Comp springs (55297 & 55298) to create a 2" lift. For a Jeep that will likely see noting more extreme than driving a Forest Service road and towing a Utility Trailer, do I need a Steering Stabilizer, or Bump stops or adjustable Track Bars?
Thanks for the help and info.
You should have a steering damper, any inexpensive one is fine. You should also add 1" of bump stop at each corner. Bump stops for the rear go above the cups and for the front they go at the bottom on the spring perch. As far as track bars, you should be fine on the front, but the rear should at least get a track bar relocation bracket. If the front axle shift on the front bothers you you could get an adjustable track bar to recenter it, but most don't find it necessary for that small of a lift.
I'm planning on going with this setup. Find any issues or things you'd have done differently?
Is there anything specific I should be looking at for bump stops?
4" Lift
Required: Shocks, Springs, Bumpstops, Adjustable Track Bars, Adjustable Control Arms, Extended Brake Lines, SYE (Slip Yoke Eliminator) with a Double Cardan Driveshaft, Rear Spring Perch Relocation Brackets (or Rear Shock Mount Extensions), and Sway Bar Disconnects or a Currie Antirock
Tire Size Recommendation: 33" (or 35" with modified fenders)
emphasis mine. I haven't looked into this much, but what sort of fender modifications let people run 35s with a 4" lift?
I have 3" of bump stop in my front end due to shock length, and I have MCE fenders, so I'm kinda curious whether that's enough, or if it would require highlines and/or cutting in the rear as well. I plan for an eventual body lift, but not until I get into an LJ first, and I'd rather not have a hard link in timing connecting the next Jeep and the next set of tires if I can avoid it.
To run 35s with a 4" lift you'd really just be smart and add a 1.25" body lift. The one recipe that works very, very well for 35s is a 4" suspension lift, 1.25" body lift, and stock fenders with something like the MCE fender flares (or stock flares). Blaine builds them like this for a reason.
Highline fenders are not necessary whatsoever for 35s and a 4" lift. If you want a recipe for 35s that is proven to work many times over, add the body lift and call it a day. With the MCE fenders you're already setup.
the body lift is the plan, I just don't want to do it to this TJ knowing I'm going be replacing it and was just thinking if I happen to need new tires before I've replaced it with an LJ, I'd rather buy 35s if it wouldn't completely screw things up without the BL.
If things go to plan I shouldn't have to make that call because I'll have the LJ before these tires wear out. But my wife and I don't always agree on the best ways to spend our money, so...
Before I bought my current TJ and Blaine was going to build my last TJ for me, he and I had a phone conversation. I asked him if I should swap out the stock fenders for something like GenRight fenders or similar to run the 35s. He told me no, don't do it. He mentioned that if setup properly, the tires will stuff perfectly into the stock fenders, and the fender flares are designed to flex. Of course since you have the MCE fender flares, that eliminates the possibility of damaging or cracking a stock fender.
Basically what I took away from that conversation with him was that there was no reason whatsoever to go with tube fenders for 35s and a 4" suspension lift + 1.25" body lift.
The only reason I have the GenRights on my current TJ is of course because it came with them. However, had it not, I would have just kept the stock fenders.
I got the MCE's 100% for looks. I just love that flat fender look of the old MBs. I'm not sure I'll do them on the next one though because as you said, it's not really needed for clearance and I'm not sure they give enough of the MB look to justify themselves on that basis. With the roll cage, the modern door opening, the squared rear fender arch, and the wide stance just it just isn't going to get there. If I do it at all it'll only be after the 35s and BL are on.
Wow, great read on the lifts and answers a ton of questions. I have a 2006 65t anniversary TJ that is unmolested with the exception of 31x10.5 tires. We just got my daughter a 98 TJ with the same size tires and it has a 2.5” lift on (springs and shocks only). I love the way it sits and am thinking about lifting mine as well and like to do things right, so I appreciate the post. When it comes to tires, would you recommend changing the gears with 31” tires?
Thank you!If you have 3.07 gears or 3.73 with an auto transmission I'd regear it. If 3.73 and 6 speed I'd leave it.
But I also drive my Jeep primarily between 7300 and 10000' elevation, so I probably need the revs more than you do.
The best advice I could give is just do it, but with the understanding you might want to regear afterward. If you do, then it's not a surprise, and if you don't, then the surprise is that you saved $2500.
Okay so imagine you’ve drawn a straight line from the front of the engine to the rear axle. What you are shooting for is as straight a line as possible. When you lift a Jeep that same line from rear axle to transfer case no longer intersects the engine. It shoots up above the engine. So doing a motor mount lift helps place the engine in line with the rear diff and transfer case. In summary you are tilting the driveline down towards the rear axle (by lifting engine and dropping transfer case) in order to compensate for the lift. Drawing a line on paper will help and I will post some pics to show in a min. Please answer one question so I can properly draw the picture. Do you have an SYE in the rear?Can you help my understanding on drive line angles? A lift pushes the axles down away from the TC and everything else bolted to the frame, right? So I understand why lowering the TC or adding SYE/DCDS is sometimes needed. But what does the TC drop do to the connection between the transmission and the TC? How does a MML help? Seems like now you've raised the engine and dropped the axles and twisted everything else in between. Finally, where does a body lift come into this (just for making room for a tummy tuck?)? Thanks for answering my many questions.
No, but I do have an LJ and I know that helps reduce the severity of the angles.Do you have an SYE in the rear?
It does. That usually means you need less TC drop to fix the angle. If you choose to do a MML and a BL (they are paired together almost always) that takes the place of a inch or two transfer case drop. So depending on the lift height you’re shooting for you can get away with a MML and not lower your TC.No, but I do have an LJ and I know that helps reduce the severity of the angles.
This is really helpful. I was trying to imagine moving the whole drivetrain up or down together, but now I realize it's more like trying to pivot it while keeping it in the same (ish) original line. I'm going for about 2.5" suspension lift and about 1" body lift. My LJ already has 33s and a sad 2" BB. I want to give the tires a little more room to play, but not looking to do anything huge. This will be my DD and occasional trail ride.It does. That usually means you need less TC drop to fix the angle. If you choose to do a MML and a BL (they are paired together almost always) that takes the place of a inch or two transfer case drop. So depending on the lift height you’re shooting for you can get away with a MML and not lower your TC.
