1. Want to have your TJ featured as the November 2018 "Ride of the Month"? The winner will receive a $200 gift card from Metalcloak! Click here to submit a photo of your TJ. Submissions are accepted until October 20th!
    Dismiss Notice
A Beginners Guide to Lifting Your Jeep Wrangler TJ
Discussion in 'TJ Frequently Asked Questions' started by Chris, Jan 10, 2016.
  1. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    No, it won’t cause any issue with the driveshaft as long as you lower the transfer case or install a SYE and CV driveshaft.
  2. CodaMan
    CodaMan California Prisoner (for only a while longer)
    Mar 9, 2017
    2,588
    2,527
    California (for now)
    It's the vibrations that cause damage, so you will need to eliminate them. As @Chris stated above, SYE and CV driveshaft or lower the TC skid until the vibrations disappear.
  3. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    Worth adding as well is that a 1” MML will help with the driveshaft angle and likely require a lot less transfer case drop.
    CodaMan likes this.
  4. Tony13
    Tony13 New Member
    Apr 17, 2018
    23
    12
    Dallas, Texas, USA
    Has anyone added better shocks to the Skyjacker 4" lift? The ride does not bother me too much but I know it could be much better, My wife had a JKU Rubicon with Teraflex lift and Fox reservoir shocks and it was pretty awesome. Just wondering what shocks work well with the Skyjacker lift. Thanks!
  5. JMT
    JMT The Jeep Guy
    Supporting Member Ride of the Month Winner
    Feb 27, 2017
    5,814
    5,380
    Texas Hill Country, United States
    Can't comment for every setup, but most like Fox Shocks with a heavier Jeep, like a JKU. For our lighter TJ's, a shock like the Rancho 5000X runs well. The Fox (and this is subjective), is too harsh for most TJ owners. Rancho 5000X found here. I think the $50 rebate is still available. They will work well with your Teraflex lift.
    https://www.allensoffroad.com/shock...Rancho-Shocks-TJ-LJ/Rancho-5000X-Shocks-TJ-LJ
  6. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    If you want the smoothest ride you will get on a TJ, it's going to be the Rancho RS5000X or RS9000 shocks.
    So far I've run OME Nitrochargers, Bilstein 5100s, Fox 2.0s, and Rancho RS5000X shocks. The Ranchos blow the others away in terms of ride quality. There's not even a question about it.
    Those Fox shocks will ride good on a JKU, because it's much larger and heavier. They ride very poorly on a TJ though in my opinion, as they are much too stuff.
    CodaMan likes this.
  7. Tony13
    Tony13 New Member
    Apr 17, 2018
    23
    12
    Dallas, Texas, USA
    Awesome thanks!
    Chris likes this.
  8. Trident72
    Trident72 TJ Enthusiast
    Dec 27, 2017
    104
    139
    Glastonbury
    Any recommendations on a 1-1.25 in body lift kit? There’s so many I’m not sure what the best option is. I have a 2.5 in lift on my 04 TJ and want to run 33’s. Also if someone could explain bump stop to me. What is it. How is it installed(pix would help) and how do I determine how much I need?
  9. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    Honestly, they're just pucks to lift the body, so you really can't go wrong with any brand.
    A few common ones that people often run are:
    JKS 1.25" body lift
    Rough Country 1.25" body lift
    Daystar 1" body lift
    You can't go wrong with any of those.
  10. Trident72
    Dec 27, 2017
    104
    139
    Glastonbury
    Solid or rubber?
  11. glwood
    glwood TJ Expert
    Sep 16, 2016
    4,632
    4,110
    Albuquerque, NM
    Bump stops are on the inside of the spring. They keep the spring from being collapsed all the way. The factory foam bump stops are on the top spring perch, and contact the bottom perch if the axle moves all the way up. Longer springs require bump stop spacers of some sort, in order to not destroy your shock absorbers, and keep your tires from messing up your fenders, basically.
    #71 glwood, May 18, 2018
  12. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    Read this, it's very, very informative:
    How to set your bump stop on a Jeep Wrangler TJ
    In a nutshell though, your bump stops are what keeps your wheel / tire from hitting your fender, as well as other components (i.e. track bars, steering, etc.) from bottom out or hitting each other.
    Think of it this way... If you put a 4" lift on your TJ with larder 33" tires and don't bother to add more bump stop, you're going to crush your fenders the first time you try to flex it off-road, and you're likely going to crush other components as well, such as track bars hitting the diff cover, etc.
    skrelnik likes this.
  13. Damazzaro
    Damazzaro Member
    Jan 22, 2018
    86
    88
    Michigan, United States
    Maybe someone could give a little advice for what I'm looking to do. Down the road I look to eventually upgrade everything to be able to support a 35" tire. (Yes, brakes, gears, CV, etc.) If I'm properly comprehending everything I've read, I shouldn't have issues while running a 3.5"-4" lift with Metalcloak overline front+rear fenders. I've owned a zone combo lift on my old 2000 sport but would rather take a higher quality route this time around. I don't do any serious rock crawling or mud bogging; I only do the occasional weekend trips and would eventually love to trailer it to the western portions of the US. My Jeep ('06 Rubicon) will be my daily driver for another half a year or so until I am able to purchase a more MPG friendly vehicle.
    Since I'm not doing any serious off-roading I figured a Rubicon Express 3.5" super-flex would be a decent route. There's two options for those: One that sits at ~$950 without any control arms or shocks, and one that is $1500 with control arms but lacks shocks.
    My other thought is since the more expensive RE kit is already $1500, I might as well save for the Metalcloak 3.5" Duroflex Suspension. That one is ~$2000 minus the shocks.
    I guess I'm real crossed on if saving my money to purchase a high-end kit would be worth it over purchasing a mid-tier kit w/ excellent shocks. Has anyone gone either route and regret their decision? Really just looking for some advice. Since this is my new Jeep, and is nearly all stock at this point, I'd like to build it right and build it to last. At the same time I don't want to overbuild it and never see the benefit of the high-end lift kits.
  14. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    I don't recommend lift "kits" much anymore. I suggest piecing it together yourself. The RE kits are okay, but nothing more than that. I'd still be more inclined to use a control arm with a nice joint such as a Johnny Joint (i.e. Currie, Savvy, Rokmen, etc.) or the Duroflex joint (Metalcloak).
    In addition, most of the shocks that come with lift kits are garbage. I've run almost every shock there is on my TJ, and the Rancho RS5000X is by far the best, no joke.
    So if it was me, I'd piece something together. The only "kits" I suggest would be high end ones such as Currie, Metalcloak, etc. But if you don't want to spend that sort of money, I'd piece a lift together personally.
  15. bobthetj03
    bobthetj03 TJ Guru
    Feb 3, 2017
    6,393
    6,737
    Gateway to the Redwoods, Northern California
    Are you going to make the jump straight to 35's, or do it gradually over time?
  16. Damazzaro
    Damazzaro Member
    Jan 22, 2018
    86
    88
    Appreciate the feedback. I saw your post about the Ranchos on another thread and actually plan to run those eventually! If I were to purchase the Metalcloak 3.5" lift over piecing together a 3.5" at roughly $1200-$1500, would I notice any major differences. If I don't do any extreme wheeling am I going to see the benefit of MC over a pieced together kit? I'm inclined to just wait a few more months, save money and go with a more expensive option, but my access to a lift + garage may go away in that time. I'd need to obviously factor in labor costs of someone installing if I do lose access.
    I think a smarter route for me would be to move to 33s first, then gradually over a year or so make the transition to 35s. I'd prefer to not upgrade my suspension a second time for 35s but to just get my suspension done right the first time.
  17. Chris
    Chris Administrator
    Staff Member
    Thread Starter
    Sep 28, 2015
    28,668
    17,135
    Salem, Oregon
    The Metalcloak lift will last longer than let's say an RE lift. The bushings used in that kit are going to be much higher quality than the ones that are used in something like a RE, Zone, Rough Country lift, etc.
    In terms of ride quality though, that's mostly dictated by your shocks to be honest.
    It also pays to have adjustable control arms. I'd always avoid buying lifts with the fixed length control arms personally. The higher end RE lifts have adjustable control arms though, so at that point I think it just comes down to bushings. In which case, if you're not doing anything serious off-road that requires maximum articulation, you're probably fine with any bushing at that point!
  18. bobthetj03
    bobthetj03 TJ Guru
    Feb 3, 2017
    6,393
    6,737
    I think that is a smart way to go. You may even find out that 33's will get you 99% of the places you want to go and get you the look you desire.
    My advise would be to piece together the items you need. Spend the coin on a good quality set of adjustable control arms, like Currie/Savvy or Metal Cloak. Those will carry over into your future plans, so you'll only need to buy them once. 3" springs and a 1" body lift/MML will give you the clearance for 33's paired with the proper shocks for said lift. If you do indeed decide to get MC's Overline fenders, then you'll already be set up for running 35's(sans a brake upgrade). You'll also want to think about a re-gear at some point as well.
  19. Serbonze
    Serbonze TJ Neophyte
    Nov 12, 2015
    1,594
    1,493
    Florida, USA
    If you’re not doing any serious off roading, then you are already over building this this Jeep by adding MC fenders, gears, brakes, and steering to run 35s.
    That being said, I totally understand where you are coming from and I completely overbuilt mine because I wanted the best quality that I could get. I don’t regret my decision at all, because I know that my Jeep can handle whatever I can throw at it. Additionally, in the grand scheme of things, it didn’t cost all that much more.
    A word of caution on the MC springs. They are designed for very heavy Jeeps and will net about 5” on a light TJ. I used the Currie 4” springs, and with the Rocksport long travel shocks I can use all of the extended length (I believe second longest to MC) of those springs.
  20. Damazzaro
    Damazzaro Member
    Jan 22, 2018
    86
    88
    Thanks again! I'll take all that in account.
    Ya I'm sure 33s would be perfectly okay with that I do. That's what I had on my last rig. Since I recently graduated from college I still have the mindset of getting big tires and having the Jeep look big. Heh. Maybe it'll fade by the time I actually go to upgrade to 35s. And since I now have a rubicon I'm thinking why not 35s?
    I really enjoy the look of the MC fenders. Especially when the fender portion is painted to match body color. That's what I plan on doing. Vanco brakes would be an excellent upgrade even if I just plan to run 33s, they'll be a huge upgrade over stock. The rest, yea. I need to decide if it's worth it. Like you said, I'd also like to know my Jeep to handle most things I throw at it. And hey, maybe I do start doing more intense wheeling as this Rubicon will be my full time toy in about 6 months to a year. You never know.
    And thanks for the heads up about the MC springs.
Share This Page
