A/C not working
Raul G
Laredo tx
So a while back I had replaced the blower resistor on my Jeep. It would only work on a certain level witch was low, since I replaced the blower motor resistor it worked like new. This morning my Jeep would not blow any air in any level. I piped the hood open and checke did the clutch was engaging and it was. Anyone have. Any idea what it may be?? anything helps!!
Normally a worn out blower motor causes the resistor and/or switch to fail. You repaired one of the symptoms by replacing the resistor, but the underlying problem is still there. Check the blower motor for excessive current draw, the resistor for resistance and the switch plug for signs of overheating.
