Having some trouble with my AC. I know enough about these systems to do simple R&R and evacuate/fill refrigerant, but that's about it. I've got a 98 4.0 and so far here's what I know:
AC blows room temp air at max cold setting and max blower motor setting.
Dash controls/blower motor work.
Compressor works.
Heater core has been blocked off due to a leak (I live in Tx so I'll fix it eventually, but its not a priority right now).
Hooked up gauges, Low side reads ~25-60psi (comp kicks on around 60, shuts off around 25), High side reads 100-150psi.
There's some neon stuff around the low side connection, I'm assuming this is some kind of uv leak detection.
After I disconnected the high side from the gauges, there appeared to be some kind of oily substance coming out of the connection/schrader valve. It ppeared dark green on a paper towel. I'm assuming this is compressor oil?
Not sure where to go from here. Idk if freon is leaking out past either schrader valve and i don't want to just willy nilly add freon and over-fill/pressure the system because I know that's just as bad.
I'm going to try and evacuate the system and maybe change out the schrader valves and refill, but if anyone has any other ideas, feel free to let me know, I'm just kind of working off of basic/common knowledge here
Compressor works.
