Im in the process of changing out my absolutley rusted muffler, with a cat back system, and while the skid plate is off I have been searching and reading the various topics on this forum. And have settled on the using the following approach to help restore my new to me TJ. 1. Wire brush loose rust. 2. Spray rustoleum rust reformer, wait 24 hours. 3. Coat with rustoleum stops rust primer. 4. Final coat - rustoleum stops rust semi gloss. 5. then I will fluid film the inside using 360 nozzle. and then spray the outside areas with more fluid film
A few questions as I go about this project
1. For the painting, I have been focused mainly on the frame, skid plates, and control arms. Is there any areas I should avoid? obviously transmission and transfer case. But should i do differential and axle? My concern is covering the bolts and such with what will be 3-4 coats of paint?
2. When installing the skid plate (my tj is stock height), should i place any wasshers between it and frame? seems to me there should be some type of airgap, my frame wasnt that bad, but there were two spots where several millimeters of metal about 3" long flaked off where these two peices met. the washers would also make it easier later for future fluid film applications
3. Im installing new skid plate bolts and transmission mount nuts just to be safe. In general when working on my TJ, what is the conensus on when to use anti-seize vs blue lock tite?
Thanks!
Thanks!
