A lesson learned—keep it light and nimble!
Irun
Irun
Mortality is a reality!
Virginia
What is the backlash? 0.0035"?
0.035. However, I'm going to start over and measure when I'm fresher. Pinion bearing pre-load was measuring 20 in/lb, but that was with the seal. I don't see any indication the Pinion was out, so I'm starting with the backlash.
Reactions: reddvltj
SkylinesSuck
TJ Expert
Northern VA
That makes me feel cheap. At least buy me beers first. Speaking of which, I'm due for a kitchen pass and no assigned overtime in sight 😎
  • Love
Reactions: Irun
Mike_H
autos are better - WRWD508
So, you started at zero on the dial indicator? Then you're measuring closer to 0.0365" That seems WAY outta whack. I concur with your decision to remeasure. Make sure your bearing caps are tightened to spec.
Reactions: Irun
Irun
Irun
Virginia
Yep, started at zero and those were the numbers I saw. I also ran a quick pattern, which showed that I need to go deeper. Like I said, I'll regroup when there is time!
Reactions: reddvltj and RINC
Irun
Irun
Virginia
After picking up the Milwaukee 1/4" (48-22-9004) and 3/8" (48-22-9008) socket set for "compact" trail tools, I completed the set with the following:
Packout 11 compartment case - 48-22-8431;
1/4" and 3/8" socket trays - 48-22-9486T; and
Packout 5 compartment case (For assorted nuts, washers, bolts, etc.) - 48-22-8436
While you can buy the socket sets together, with the case, by ordering it all separate I was able to get it all for the same price, including the extra 5 compartment case.
[/URL]
Apparition
Moab June 11-16th 2023
Twin Cities, MN
[/URL][/URL]
That has been my go to socket for a while now. Good choice on putting it all together.
You're going to need more packout stuff.
Irun
Irun
Virginia
Are you changing the title to "keep the Jeep light and nimble, so you can load it down with Packout boxes?"
I have a general rule where extra weight, besides myself, in the Jeep is limited to 120lbs. This means that only a couple of these will go in the vehicle with me. They will be used to hold:
- fluids;
- spare u-joints;
- a few critical sensors and hoses;
- a small assortment of nuts & bolts;
- a small assortment of electrical connectors and wire; and
- tools
I also have a Carhart canvas bag that my recovery gear goes in, along with a small cooler. All of that usually comes in well under my weight limit. Since I trailer the Jeep, the rest will go in the truck, to include camping gear, more parts, fluids, tools, etc. The aggregation of these just helps me be much better organized and ready to go quickly! :)
Apparition
Twin Cities, MN
I have a general rule where extra weight, besides myself, in the Jeep is limited to 120lbs. This means that only only a couple of these will go in the vehicle with me. They will be used to hold:
- fluids;
- spare u-joints;
- tools
Will you add packout mounting plate? If it works out space wise in mine I might.
Irun
Irun
Virginia
I'm undecided. Typically, I just use the seat brackets and ratchet straps to tie the boxes down. My main point for the indecision is whether the mounting plate would keep everything in place in the event of a rollover. I'd likely end up with ratchet straps anyway, so I'm not convinced going with the plate would provide any value. However, if it held up to the weight upside down, it would make access to the stuff better, when in the correct upright position. Make sense? :unsure:
psrivats
You can't see me!
OR, USA
- fluids;
- spare u-joints;
- tools
Why specifically 120 lb?
Reactions: Irun
