A lesson learned—keep it light and nimble!
I used the PSC cooler for the trans and power steering. It sits nicely behind the grill and works well. I have a B&M gauge to install but I’m waiting to drop the pan to install it. I thought about just putting it in the return line but wasn’t sure it would give me an accurate reading.
Reactions: Irun
Here's a write up on one I did. I just replaced the pan with a Dorman version, which has a drain plug. In my case I used an adapter to install the sensor into the pan. It has worked perfectly for me. The part numbers are in here:
https://wranglertjforum.com/threads/installing-a-transmission-temperature-guage-in-a-42rle.28410/
Reactions: Lax22
Until you have that gauge working, you have no idea how well it works or doesn't. That and the sender goes in the pan.
Reactions: Lax22 and Irun
OEM radiator
New Mopar radiator
Reactions: Irun
Not letting that slow me down, I installed a very low miles Mopar alternator, new pulleys, fan belt, etc. And, got the B&M transmission and PSC power steering coolers in. I had to go through numerous test fits before clearing the grill and condenser.
Was hoping to finish up the A/C system refresh yesterday. However, when I pulled the new condenser out of the box and inspected it, I found this
I was a quality engineer at a company that manufactured AC lines, it was a shitty company and we had all sorts of problems with braze rings while I was there. If we were able to find these defects I'm amazed they made it to your shop. Is that a mopar part?
Reactions: Irun
No. Spectra. Very poor quality!
Well I know to avoid their stuff now lol. That's a braze ring that didn't break down, happens all the time but a decent quality program would catch it. If the torches on the braze machine aren't set perfectly you'll have those kinds of issues
Reactions: Irun
Any idea where to mount the PSC cooler if I didnt have space to mount it horizontally in the grill? Mount it vertically to a side?
Definitely looks like the cooler you have is on the large size. I'd probably get a different cooler, or, if that's not an option, see if there's a place on the frame you could use. FWIW, this is why I used the B&M 70264. It was the largest I could fit and still run the 16" PSC cooler in the grill.
Reactions: Wildman
Progressing slowly. Went to install the transmission temperature guage and discovered Amazon made a mistake in my order. I bought a autometer 2267 adapter for the pan and they sent a 2277.
Moving forward, I installed the Daystar boot on the blokout plate. I also painted a tan Tuffy console I had and installed the guage.
