A little low on the front end
Swede has a TJ
Colorado
A previous owner installed what I believe to be a 3" suspension lift. I've figured out I need to get adjustable track bars to square the axles to the body.
I also noticed the front end is about 1/2" lower than the rear. Measured on the fender flare at the center of the wheel.
I've found OME trim spacers that I think will correct this.
Am I correct?
Also, are there any common issues that may show up while doing this?
Honestly, unless the visual rake really bothers you, I probably wouldn't worry about a half inch difference, but that's just me. You could always carry around a little extra weight in the back of the Jeep. It may not take much because weight in the back end will also bring the front end up slightly.
Do you have a front bumper and winch you are committed to? If not, do that first. The extra weight will lower the front end further and you will have to buy new spacers again.
Reactions: SvtLdr
