A rear main seal that is giving me fits!
Irun
Jeep Addict
Virginia
I've done many rear main seals, without issues. However, I now have one on a friends vehicle that is being obstinate. I've helped him replace it twice and it still leaks ever so slightly. I know it was installed correctly and I didn't feel any groove worn in the crank. Any suggestions on what to do next? I really wish there was some sort of option that had two sealing lips and not one! :(
RMETeeJay
CO, USA
Gotta ask because you don't say. Have you determined that there is no oil coming down from higher up?
Reactions: Irun
tworley
Megajeep!
Arvada, CO
Ugh this is something I need to check off my list too. The rear of the pan isnt leaking, but up front near the timing chain cover is bad. I thought fel-pro would have been the recommended seal.
Reactions: Tob and Irun
jeepguy03
Connecticut
I've replaced probably 10 Jeep 4.0L rear main seals on Jeeps I've owned as well as family/friends' Jeeps, and I still managed to screw mine up and get the oil pan seal rolled over, causing it to leak soon after. 🤦‍♂️. I thought the rear main seal was bad until I pulled the oil pan and realized my error.
Irun
Irun
Jeep Addict
Virginia
I used a fel-pro and it leaked on me. Replaced it with a Mopar and its been leak free for years and many miles now. I couldn't tell the difference, but its enough of a persnickety job, I felt it was worth getting the OEM seal.
I'll be doing this soon on mine. I was strongly advised to use a Mopar rear main seal and oil pan gasket to have the best chance of success.
I honestly never even thought about a Mopar RMS. I also need to replace the one in my LJ, so I ordered two. One for myself and one for him. Thanks and I'll report back on progress! (y)
Reactions: Tob and Mike_H
Irun
Irun
Jeep Addict
Virginia
Not a hard job, but not a fun one either. Some of the bolts up front on the oil pan go into the aluminum timing cover. It's very, very common for those to get stripped! :(
Jamison C
Heil Savvy 🙋‍♂️
Sedona, AZ
I did the RMS with the auto swap since I had everything apart. Used a felpro and it leaks. Guess I’ll try the Mopar one as well.
Reactions: Irun
SkylinesSuck
TJ Expert
Northern VA
Fel-Pro BS6141 is I believe the Ford 292 seal I had used before. I'd check the measurements for it though just to make sure---I'm having a tough time finding the thread that had recommended it. I'm not 100% on it being double lipped now but I think that was the reason it was recommended to me way back when. It's been a while.
I'm curious to see what they all look like compared to each other, especially the "new double lipped" FelPro meant for Jeeps and the Mopar. If I knew a RMS wouldn't leak, I'd happily pay 3x what the other costs for it.
Reactions: Tob
Irun
Irun
Jeep Addict
Virginia
Fel-Pro BS 40612 Rear Engine Main Seal Set https://www.amazon.com/dp/B000C2E7YQ/?tag=wranglerorg-20
Claims it's double lipped. I'll try and find the Ford one I was telling you about earlier.
After I talked to you I remembered there are in fact two different style RMS. When I did my '99, it used the style you linked to (picture below with the wings)
I believe the break is 2001 - 2006, where they all use this version (picture below without wings)
Reactions: SkylinesSuck
Rcroane
Virginia
Just curious....what type of oil is in the Jeep? If synthetic or blend, switch to conventional like NAPA 10W-30 first to see if that stops the leak.
JEEPCJTJ
TJ Expert
Half way between Pittsburgh and Cleveland
When I clicked the link SkylinesSuck posted it said "This does not fit 2006 Jeep Wrangler" so I was wondering why it says that.
