They will fit but without any backspacing/offset you may need to add a washer or two to the steering stops.
Mine got a set of 31" bfg ko's way back in 2001 when it was bone stock...
With quick disconnects fitted they rubbed on the sway bar at full lock during articulation on the stock rims.
I fitted the pictured 31x10.5x15 on 15x8 with 3.75 BS to avoid it.
You can see I don't mind a little rubbing but if anything, or anyone, rubs on myyyyy Jeep.
You can see I don't mind a little rubbing but if anything, or anyone, rubs on myyyyy Jeep...
ara:
Awesome thanks for all the info!!!!! greatly appreciate it.
