Interesting, that’s hard to beat. And their lead time is great too.Thanks, that fusion bare housing is listed at $1300 for a Dana 60 builder housing (3.5")
what super 60 housing is $995? thats a good pricethat super 60 housing is $995, what is different ? you could finish those 3.5" tubes any way you wanted.
on the fusion 4x4 site they have the elite HP 60 housing starting at 1300 and the super HP 60 starting at 995. but then you click onto it and it shows the same housing and same 1295 so i guess it's not correct.what super 60 housing is $995? thats a good price
14B is low pinion I believe so its not something I'd consider for front axle.on the fusion 4x4 site they have the elite HP 60 housing starting at 1300 and the super HP 60 starting at 995. but then you click onto it and it shows the same housing and same 1295 so i guess it's not correct.
and forgive my ignorance but can anybody explain the difference of what a 14 bolt is.
WOD offers a shaved 14 housing for 1250. i know they are pigs but how does a shaved 14 compare to the 60 for hang?
this is 1 of the best prices i've found for a Dana 60 complete axle.14B is low pinion I believe so its not something I'd consider for front axle.
Well that's interesting. I've never heard those guys, they're not exactly in my neighborhood but they're only a few hours away (south of Portland). I called up and talked to the sales guy. They only run the 60 casting, so if I went this direction I'd have to buy a new locker but they got the best price around and even beat Fusion. For JK tube length + 3" on each side = $1230 + ship.this is 1 of the best prices i've found for a Dana 60 complete axle.
https://emeraldwest.com/motorsports/products/crawl-king-kingpin-60-front-axle/
IDK whether to build or buy really. by the time you piece it together your not far off a few of these. i have to much wheelbase to stay 35 im gonna want 39's eventually.
The factory GM 14 bolt, when shaved, can match or exceed the factory Dana/Spicer low pinion Dana 60 and even the factory Dana 44.I know they are pigs but how does a shaved 14 compare to the 60 for hang?
What's driving this thinking?I'm still trying to figure out my long-term plan (3") leaning toward 44 center section with the 60 outers.
I believe he already has a Dana 44 in-hand and the achilles heel of the 44 is the 44 sized balljoints when paired with a tire taller than a 35.What's driving this thinking?
Yup. I went from a high pinion, Pro-Rock 60 to a shaved 14 bolt - and the ground clearance is about the same. The 14 bolt certainly looses a bit of pinion clearance, and it is quite a bit heavier, but after smoking the Pro-Rock five times I’ll take the trade off.The factory GM 14 bolt, when shaved, can match or exceed the factory Dana/Spicer low pinion Dana 60 and even the factory Dana 44.
A factory Dana 60 uses a 9.75” ring gear for rear axle applications and legacy front axle applications. The GM 14 Bolt uses a 10.5” ring gear.
Some folks shave the GM 14 Bolt down to around 10” for max ground clearance.
All axle ground clearances are measured from axle centerline to lowest portion of the differential center section.
The GM 14 Bolt is attractive for it’s big tubes, huge center section, ability to be shaved, and its pinion support. It’s almost indestructible.
- GM 14 Bolt ground clearance: ~6.5”
- Dana 60 ground clearance: ~6.0”
- Shaved Housing: ~5.5 - 5.8”
- Shaved Housing Shaved Ring Gear: ~ less than 5.5” (it varies). *More ground clearance than a 8.5” ring geared Dana 44.
Correct, the JK44 seems to be sufficient for me with 37s but I'd like to get unlocking hubs + 35 spline outers+ big ball joints. Its hard to tell for example with the UD60 housing how much worse is the casting for up-travel vs a Dana 44? Everyone talks about ground clearance but not how it integrates on the top.I believe he already has a Dana 44 in-hand and the achilles heel of the 44 is the 44 sized balljoints when paired with a tire taller than a 35.
WOW 5 times. Your were smoking the gearset? Yours was a high pinion? Guess V8 has something to do with that. I was talking to the guy at Emerald WEst and he was saying theyve been running these UD60 (HP) housings in rear applications as well. They started with a load bolt addition but then pulled the load bolt and now run them as is.Yup. I went from a high pinion, Pro-Rock 60 to a shaved 14 bolt - and the ground clearance is about the same. The 14 bolt certainly looses a bit of pinion clearance, and it is quite a bit heavier, but after smoking the Pro-Rock five times I’ll take the trade off.
This one has me scratching my head as to why. I wheel almost exclusively with 1st Generation Broncos. They all run the stock 9" in the rear and stock 44 up front. They also all run V8s and 37" tires. The only breakages I've ever seen with them have been a few front U joints and one blown hub. This is over a 5+ year history. I'm not aware of any ball joint issues with them, but they don't daily drive these either.Correct, the JK44 seems to be sufficient for me with 37s but I'd like to get unlocking hubs + 35 spline outers+ big ball joints. Its hard to tell for example with the UD60 housing how much worse is the casting for up-travel vs a Dana 44? Everyone talks about ground clearance but not how it integrates on the top.
Yes, the Pro-rock 60 was a high pinion. 1 ring and pinion, 2 bent shafts, 1 broken shaft - all before the Hemi. The pro-rock was also semi float - which had a bunch to do with it. With the Hemi, last fall I killed the R&P, along with destroying the ARB carrier - broke the case in 4 places. That was kind of the last straw...WOW 5 times. Your were smoking the gearset? Yours was a high pinion? Guess V8 has something to do with that. I was talking to the guy at Emerald WEst and he was saying theyve been running these UD60 (HP) housings in rear applications as well. They started with a load bolt addition but then pulled the load bolt and now run them as is.
Maybe the 14 Bolt is a bad example, but sometimes a low pinion shines when it comes to uptravel. But to advocate for the other side, a high pinion is very helpful for down travel.Its hard to tell for example with the UD60 housing how much worse is the casting for up-travel vs a Dana 44? Everyone talks about ground clearance but not how it integrates on the top.
That is an excellent price. I gave him a call yesterday and talked to him about the high pinion 60 he sells.this is 1 of the best prices i've found for a Dana 60 complete axle.
