Abs light came on 97 sahara
Sweetlou602
Bossier City, La
I just got finished installing a new bumper and some rock sliders on my jeep. Everything went smooth and when I cranked it to pull out of the garage I noticed my ABS light was on. I have a Dana 44 from the factory on my Sahara and didn't think it even had ABS on it. It drives no different and brakes the same as before. Any ideas on what this may be? It's driving me crazy!
Look on the tray in front of the firewall on the driver's side. Kind of looks like a battery tray but it's not. That's where the ABS pump is located if you have ABS. Is there a gizmo with brake lines running to it mounted on that flat tray just behind the tire well and in front of the firewall, beneath the brake booster? If so you have ABS. If there's nothing on that tray you don't have ABS.
I do have the pump, I opened the Fuse panel though and the abs system relay as well as the abs pump relay are removed.
