Acceleration problem with my Jeep Wrangler TJ 4.0
stefio1992
italy
hello guys i have had a problem for a year with my jeep tj 4.0 1996 it is emptying in acceleration and it is uncertain
spark plug changed
changed spark plug cable
throttle body cleaning
o2 changed 4x times ntk
new exhaust with 200 cell catalyst
what can be the fuel pump coil or filter
now I don't get any errors in dash board car
before error 27
with obd2 P0132
P0203 P0202 P0201
thank you
Goatman
TJ Expert
Upstate NY
Check what your fuel pressure is. I'm sure you have checked the air filter and confirmed there is no other blockage to the engine. This type of problem is commonly fuel related. Or sometimes ignition timing.
Other than acceleration, is there any other problems? Bad idle? Preignition? Backfire?
Chris
Administrator
Staff Member
Salem, Oregon
What kind of spark plugs did you use? What did you gap them to?
Also, a 1996 is a YJ, not a TJ.
S
stefio1992
italy
[QUOTE = "lowranger, post: 538793, membro: 2463"]
Bene, vedo il problema. Non hanno costruito un TJ nel 1996.
[/CITAZIONE]
built October 1996 registered December 1996
S
stefio1992
italy
[QUOTE = "Chris, post: 538829, membro: 1"]
Che tipo di candele hai usato? A cosa li hai spalancati?
Inoltre, un 1996 è un YJ, non un TJ.
[/ CITAZIONE]
i live in italy i use xp 895 brand autolite
taylormade73
Apprentice Thread Derailer
Ohio
[/CITAZIONE]
They actually start production runs for a year the Year prior. So a 1997 would have production beginning in 96. I think it was meant more as a light-hearted joke.
Wildman
Over Analizer Extraordinaire...............
In the hills of WA
The YJ ended production in 1995 and the TJ started production in 1996 but was released as a 1997 year vehicle. They did a early release of in the summer of 1996 but all are called a 1997. I have a EARLY build 1997 TJ. Mine was built in 1-96 so yes they were built in 1996 but Jeep called them a 1997. They used parts from the YJ like the heater controls and as I am finding out the wiring on the early ones are differnent. But that only applies up to about June 96.
CharlesHS
Carmel Mountain
To clarify production dates...
The YJ did stop production in December 1995, but there were numerous YJs remaining. They were sold until early 1996.
The TJ started production in January 1996 (dubbed 1996.5), but the TJs made it to the showrooms in April 1996. .
jjvw
Now 100% Metalcloak free
Colorado, USA
The three p020x codes are your fuel injectors. Which could cause trouble with the O2 sensors.
Have you done anything to the injectors recently?
Reactions: DWR
