Acceleration problem with my Jeep Wrangler TJ 4.0
Wildman
Over Analizer Extraordinaire...............
In the hills of WA
Have you done a compression test on each cylinder? Also as suggested I'd check your fuel pressure and make sure it is correct. It doesn't sound right in the videos.
CharlesHS
Carmel Mountain
Please help me for fix the problem
As previously posted.... check the fuel pressure.
The lower fuel pressure can allow the engine to run at idle, but when more fuel is needed due to the increase in throttle the drop in fuel pressure will starve the engine and the power will drop off.
S
stefio1992
italy
at this point I replace the injectors and the pump and float which do you recommend?
because it often marks me zero even if there is petrol
xxdabroxx
Central California, CA, United States
Your fuel gauge issue is likely do to a float problem with the sending unit in the fuel tank. But it could also be a wire issue that isn't directly related to the fuel pump assembly. I agree with others that the first step should be to check the fuel pressure at the rail.
Also, you can get a factory service manual for your jeep on this website. https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/
Goatman
TJ Expert
Upstate NY
Jeep held production up in 96 due to federal mandated obd2 requirements in 96 and wasn't going to update the entire YJ electronics for just 1 production year when they had the TJ replacing it in 97. So there were no USA wranglers sold as a 96. The rest of the world did not require the obd2 system. So Jeep rolled out early production TJs over in Europe and I think Australia too. Then 97 model year the TJ was sold in the US.
