Have you done a compression test on each cylinder? Also as suggested I'd check your fuel pressure and make sure it is correct. It doesn't sound right in the videos.
There wasn't a 96 anything I think...hmmm.What kind of spark plugs did you use? What did you gap them to?
Also, a 1996 is a YJ, not a TJ.
The 1996 Wranglers were left overs from 1995; in the states the TJs were released at the dealerships around April 1996.There wasn't a 96 anything I think...hmmm.
Please help me for fix the problem
If only he put TJ 1997 probably we already fixed this dude's problem.
But no no no no, he does not cave in. So it might be a YJ
unfortunately the additive fuel has been put in this one but I use it little LPG unfortunately the additive fuel has been put in this but I use it little LPG thanks to this here in Italy I can run in certain areashi update
now error 27 injector 3 i test with obd2 and tester the risult ohm is ok
should I replace all 6 with the original ones or just one?
* http://rover.ebay.com/rover/1/724-5...0001&campid=5337789113&icep_item=323809608447
* http://rover.ebay.com/rover/1/724-5...0001&campid=5337789113&icep_item=202911512154
