Hi All, I am almost done piecing my lift together for my 06 rubicon. I bought the following; Adjustable front Trac bar, Zone 3 inch lift (springs, shocks, bump stops, t-case drop (not sure if I need to install that?). I also purchased new adjustable upper and lower control arms from Metal cloak. What should the control arm length be for the All the control arms? or a good starting point? Do you recommend anything else for this lift? Tire size will be 31 maybe 32. Not looking at big wide tires. Thanks for your time
