As I have mentioned before, when I got my LJ last year it had a bit of a shake. Happened pretty often when you went above 50mph and hit bumps a certain way. Since this is my first "newer" jeep and I don't know much, I started replacing things one at a time. Started with items that even I could tell were bad. I would repair one thing, then test and see what result it had. So far I have done front brakes ( rotors, calipers, etc) and replaced my worn tires and old rims with new BFGs and 04 Rubicon Moabs. This actually seemed to do away with the shake, but it still felt like it wanted to, just didn't feel really solid yet even though it has been working OK. After looking more closely at my stock track bar and stabilizer, I could see where the track bar bushing seemed dry rotted/cracked and the stabilizer was rusty and looked like it had seen better days. ( I have 120,000 miles on the jp) Sunday we replaced worn stabilizer, as well as the track bar with an adjustable one. We returned the stabilizer mounting location to its original position. In doing this I noticed that the "newer" drilled location when the PO had lifted it seemed larger than the original hole, like it may have allowed some movement with the mounting bolt. Anyway, we put the stabilizer on, measured to center things up and a installed the track bar. Drove home, still no shake and it feels more solid but it is too soon to tell really.
So the reason for the post is that now my steering wheel is off center by about a quarter to a half of a turn when I am going straight. My next step before I purchase anything else, since I am not shaking and I have new brakes, well balanced tires, and new track bar - is going to be an alignment. Figured I would do that, see what they tell me and how it rides, and go from there. Does that sound like a good plan? Am I missing something or is there anything else I should know? Will this straighten out my crooked wheel?
Thanks! Tom
Thanks! Tom
