Does anyone have experience with Advanced Automotive in Chantilly VA for a Safe T Cap frame repair. They are on Safe T Cap's recommended installer list, but I'd like to hear from anyone with actual experience with them. Thanks.
Yes! Advanced Auto did my safetcap repair and I would highly recommend them. Not much to say other than the welds looked clean and has held up very well for about 4 years now. What I especially liked was they painted everything afterwards so it looks brand new. According to the front desk guy the owner that does it is one of the best welder in the area. I also had them do a bunch of stuff like install bump stops and replace the crossmember that somehow the 4x4 shop (Trick Trucks) forgot to do. Every shop in the area also has AA do alignments for them so they’re the go to for a lot of stuff.
https://wranglertjforum.com/threads...ed-on-with-this-frame-rust.14065/#post-229189
Best welder? Close to me? This has to be a sign to start addressing floor panels that need welding, thank you for recommendation!
That's about as solid a recommendation as I could have hoped for....thanks! I spoke to him on the phone this evening and I'm going to see him on Monday.
I'm guessing you've moved from FL to VA?
Yah sort of, been staying next to Baltimore without definite end date. This area is lacking competency, any recomendation and finding someone good at something has a weight of gold.
The shop finished the job in one day, which is what they originally told me and I'm not surprised since they are a Safe T Cap approved installer. I'm VERY pleased with the result. Here's a few photos. I wasn't present when the work was being done so I only have a few shots of the work in process. They use 3M Rubberized Undercoating inside and out. Before you ask....it wasn't cheap. If you're interested in specifics, I'll share if you PM me. If I shared publicly, I'm sure I'd hear that I should have done a frame swap.
This is the worst of my rust problem on an otherwise solid 2001 TJ Sahara 5-speed 76,000 1 family miles. Do I try to fix this like Safe-T-Caps, or spend $5,000 for a used no-rust frame swapped on?
