- Joined
- Feb 9, 2016
- Messages
- 5
I have a 97 Wrangler with a check engine light on and running rough. Put it on OBD scanner and came back that it was the throttle position sensor. Bought a new one but it doesn't match up in order to plug it into the wire harness. Went to the dealer and they said that the part was discontinued and isn't made anymore, they suggested to cut the old, discontinued one off, buy the new harness, plug, etc and install that and and then use the replacement sensor that shows up when you look up the TPS for my year....this sounds weird to me. Does that mean everyone with a 97 whose TPS goes up has to do this?? Any advice would be appreciated. I'm also going to try the FB page again. Thanks.
