Rico Suave Member Original poster Joined Nov 15, 2020 Messages 29 Location Kentucky Dec 14, 2020 #1 98 tj 2.5. Had a transmission leak, took pan off, new seal and refilled. Leaking worse than before. I used synthetic. Going to drop pan again. What sealant is recommended with or without the gasket? Looking for advice from the experts.
LONGJP2 TJ Expert Lifetime Supporting Member Joined Aug 11, 2019 Messages 5,852 Location S. Illinois Dec 14, 2020 #2 I'm no expert, but I like the Lube Locker gasket (If they make one for yours). Do you know if the mounting bolts need sealant?
CharlesHS TJ Guru Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 6,538 Location Jacksonville FL, Quezon Philippines Dec 14, 2020 #3 Mopar makes an RTV specifically for ATF. PN 82300234 Reactions: Chris
