https://www.airliftcompany.com/shop/60811/
Just to clarify, on your TJ?I think air bags would be a great option for you.
I've used Firestone air bags for this exact purpose and was very pleased, plus it's a relatively inexpensive way to keep level.
You can mount your shrader valve anywhere you want to add or release air.
But more specifically, I've not used that brand before.
It is less than 100 bucks it may be worth a go. Once you buy the kit, the bags can be replaced individually if necessary and in the TJ they install inside of the coil spring so lifting the tire off of the ground shouldn't affect the bag like on a leaf spring application. Now I just need to know what I need to know about adding it to a two inch lifted spring. Maybe the added bump stop will be enough.Actually it was not on my TJ as i only pull a small utility trailer with minimal sag.
I was just referring the use of air bags for your intended application.
My first experience with air bags was when I pulled a 2000lb P'up with a Chevy Colorado.
While the towing capacity was there, it sagged significantly.....air bags were the perfect solution.
Another option is a WDH " weight distribution hitch.....that's all i use now with the heavier loads i pull.
I use them for anti-sway also.
