I have the same issue with my 2005 lj. I'm trying to diagnose it. Did you ever get this fixed?
Mine will blow heat out floor vents but not at the same rate if you select floor vents only. What I mean is switching from floor vent only to center air vents does reduce air flow to the floor but not entirely.
Ac on it will be waem air through floor vents but with a reduced fan speed.
I think my floor vent door is partially closing. Cruise control still works and it holds vacuum from the t connection under the hood.
Any ideas on where I should look next?u research seems to indicate the 05/06 are special with blend door sticking issues.
you have an actuator that is just above the center console under the dash- This will have one of the colored lines that pulls vacuum on it- It is to the driver side of the center console- That controls air movement And you can override it with your hand - If the actuator is not holding vacuum then it needs to be replaced and they are sold at parts stores-
There is another one that is basically behind the glove box and to the right behind the passenger side front speaker-
You can literally crank the vehicle and turn the selector and see these do their job
The blend door is electronic and variable , it is basically wired in above your left shin if you are in the passenger seat- You can put on a stethoscope and hear it operate
I would start with the one that’s just about the console- Don’t be intimidated by this it is a very simple system-
It is also possible to lose vacuum at the switch in the dash- or the line from the switch to the actuator- but the actuator is can stick, become unhooked or leak.
P.S. - I’m not trying to take over the conversation I just have this fresh in my mind and wanted to offer what I could- dont let it intimidate you - there are only 3 zones (defrost, dash and feet) controlled by 2 actuators if I’m correct, all the switch does it distribute the vacuum pull, and the primary blend door is electronic - im sure there is an actuator for the fresh air vent to , but it likely is not causing the zone issue- Andy
