Air intake temperature sensor
Chris Carlile
5
Pottstown, PA.
Hi,
New member here. 2001 wrangler TJ with 4.0 I6 w/ automatic trans lifted with 31" tires. Just bought this jeep about a month ago. Idle is high and almost pulls the vehicle along even under braking. Also noting a vibration when slowing down such as when turning onto a side street. Vibration goes away when I step on the gas a bit. Looking on the forum this seemed to fit a possible description of a bad or dirty idle control valve. Following suggestions on the forum I purchased a can of throttle body cleaner and used it as described. The problem continued. A week later the check engine light came on. I then sent for a code reader on Amazon. It arrived today, plugged it in and got the indication of a bad air intake temperature sensor. Question # 1: Do the symptoms described fit a failed AIT sensor? Question # 2: I know from reading the forums an o.e.m. replacement is recommended. Looking on Amazon I can't find an o.e.m. I don't want to pay Chrysler price as it's guaranteed to be higher than on line. Any suggestions?
Thanks in advance for any assistance.
Chris Carlile
Pottstown, PA.
Chris
Administrator
Staff Member
Sep 28, 2015
37,106
Salem, Oregon
Those symptoms are certainly inline with what you'd expect from a bad IAT. If it isn't functioning correctly, the PCM doesn't know the temperature and therefore can't adjust things accordingly.
Do you know the part number for a replacement IAT by chance?
C
Chris Carlile
5
Pottstown, PA.
Thanks to both Chris and Jerry for your quick responses. I've now ordered the oem sensor which Jerry provided the Amazon information for. I have my fingers crossed this fixes the problem. I'll let you know. All the best!
C
Chris Carlile
5
Pottstown, PA.
Good afternoon. The new Air Intake Temperature sensor arrived today from amazon. Installed it removed the trouble code and took the jeep for a ride. Bingo!
Problem resolved and jeep running as it should . Thank you for you help.
Reactions: Jerry Bransford
