And?? Did you die?I popped a bead on my old wheels at 10 PSI.
Tolerances. I'm not saying you need beadlocks, but they do help get lower pressure.
Nope, but it was in my driveway when it popped off.And?? Did you die?
This is a good point to why beadlocks work.Not really. We wheeled in JV at 7.5 to 8 psi for many years on crappy AR rims. The only reason we went to beadlocks was to stop the tire from spinning on the rim.
And there is a big difference between a bump and a send.
No matter where you, or how much air pressure you are at, or what tire or beadlock, etc.... the hardest thing on components is when you get things bound up, either due to undercut or trapped between rocks, or fronts catching traction just on the other side of rock, etc... Anytime you get bound up is when things break. You can feel it bind up, but it takes experience to know to back off and stop and see, unfortunately that experience usually comes with a price and lord knows I have paid it.
My original question wasn’t “how” to wheel (I.e. when to bump, what psi to air down to, how much to bump, etc…all things you figure out with your particular setup), but which inflicts greater forces on the driveline and axle components. Obviously there are many elements involved when wheelin, but I’m not referring to things like full send, but responsible wheeling.
Part of me wants to say that getting beadlocks and airing down sub 10psi will give greater traction and allow me to crawl over obstacles easier so I don’t have to bump and endanger components. Another part of me is sayin, “but the increased traction will increase the forces on my driveline and axle components,” so which inflicts greater forces? Bumping responsibly or airing down more? Or is it a wash and don’t worry about it?
I always adopted “When in doubt, throttle out…”
…and if you’ve ever wheeled with me, you know I’m a very doubtful person.
You throttle so hard the earth rotates and you have to factor in the coriolis effect to get up the obstacle
You sound exactly like my brother. And I am VictorWhen I wheel with Victor ( @gasiorv ), he just stares and shakes his head.
