My transmission did not like Redline MTL. It is much, much smoother with the Royal Purple SynchromaxRP or Red Line for the trans fluid change? Which ever is cheaper?
anybody know if the breathers are similar on a RLE, that's not very high and i want mine higher if that's the case.I came up with a slightly different idea for the breather hose using some air compressor parts I had laying around. It's a 1/4 npt (both female) with a hose fitting. I'll replace the hose fitting with a barb tomorrow and tap the breather line into the same line as the atlas.
All I had to do was drill out the threads on one side and it was a great fit with just enough pressure to make me feel confident. I put some rtv inside just to be sure it's waterproof and a liberal amount around the base of the fitting.View attachment 280145
You're hood looks better than mine, and I've waxed mine probably 10 times. I think my problem is the hood came with crows feet, and I can't do anything about that except a re-paint. Looks nice Alex. Your paint will love you for that!Not quite up to the standards of @DylanM345 but I washed/waxed the jeep. I believe its actually the first time it's been waxed in 8 years or so..... View attachment 285719View attachment 285720
Looks great! What wax did you end up using?Not quite up to the standards of @DylanM345 but I washed/waxed the jeep. I believe its actually the first time it's been waxed in 8 years or so..... View attachment 285719View attachment 285720
DealMeguiars. I think next time I'll try to convince you to do it for me in exchange for some new parts
Now you've been civilized!Big day for the jeep. The bedrug/tread showed up today. The rug portion fit like a glove but the tread needed a bit of cutting to fit nice. I feel like I can finally go wine tasting and live the fancy life now that I'm no longer just a savage with spray in liner.
I didn't want to pull the console so the deadening isn't installed. I'll likely get some thicker stuff anyways though because the stuff they include is quite thin.
Thanks again @deadbeat son for the rear Matt's.
View attachment 285819View attachment 285820
Eh. This is civilized:Now you've been civilized!
Gotta love the tailgate table
Awesome. With all the rain I'm sure they will be put to good use saturday!!!Your front mats are cleaned up and ready.
"Do you have any Gray Poupon?Now you can hold your pinky out while you sip that wine!
That looks like Jim at Lake Pilsbury.Not for long!
