TJ Fest 2021
Alex01 Silver Sport Build Thread
Alex01
Alex01
Enthusiast
Martinez, CA, USA
What is your plan for a rear sway bar?
I'll be installing an antirock rear swaybar. https://www.rockjock4x4.com/CE-9900TJR. I spoke with Blaine and he told me that while the arms may need a bit of modification when I outboard it will ultimately work nicely together.
The decision to add a rear antirock to the mix was done because in order to cut the upper mounts off the rear axle the OEM brackets had to move also. I was actually planning on running the stock one. As @Midnight LJR would say.... While it's apart I might as well.....
Midnight LJR
While it’s apart I might as well...
Sacramento, CA
I am glad my ways are rubbing off on you. 😉
mattcogdell
TN
Behind the axle or in front?
I could see having to redo the axle bracket once you out board your rear shocks.
Mike_H
Going my own way
Your using it wrong. It SAVES you money because you don’t have to take it apart twice. 😉
It saves me TIME, not money...My wife just rolls her eyes at me when I say it. The RV generator, which I pulled to bring home and see why it didn't start turned into a 1000 dollar rebuild, because, while it was out, I should probably replace the leaky seals, and If its this far apart, I might as well hone the cylinder walls, OH SNAP...this bearing has funny wear...better replace them all.
DrDmoney
El Dorado County NORCAL
That can also be read as while your wallet is open turn it upside down and dump the contents out. 🤣
Alex01
Alex01
Enthusiast
Martinez, CA, USA
Spring perches are 75% cut off (Back side of drivers side welds not cut yet). I figure the air hammer is a bit much with the kids sleeping.
I still need to install the Wizard Brackets, new rear bump stops, and the extended rear brake line (ordered) before I can take it for a spin.
My current thought is to hold off installing the rear antirock until after the outboard is completed. Unless I guess correctly on placement the lower weld on tab would need to move and I don't feel like grinding it off just so I have it for one run.
DrDmoney
Youre kicking ass on this! I would think you are fine without a rear bar for one trail run.
Edit: People with front discos only run one bar!
Reactions: Alex01
Alex01
Alex01
Enthusiast
Martinez, CA, USA
I don't think it will be the end of the world. It would have been fun to teat the midarm pre outboard with the antirock so I can see if I felt a difference with the fox shocks but o well.
On a side note.... do these parking brake pads look toast? (I know if I need to ask likely yes 🤣) I've never replaced them and they look fairly thin. The parking brake hasn't been holding great.
DrDmoney
On a side note.... do these parking brake pads look toast? (I know if I need to ask likely yes 🤣) I've never replaced them and they look fairly thin. The parking brake hasn't been holding great. View attachment 173362
They look like they still have some life on them but since you have a part you might as well…
bobthetj03
vibrajeep
NorCal
Those park brake shoes look fine. Take some emery cloth to the lining to clean them up with some brake cleaner and tighten the adjusters. Turn them until you get a slight drag.
