No kidding, tons of changes. It will be fun running the rubicon this year and comparing it to last time.Well done! Lot's of changes to the rig this year!
NextIf you can keep yourself awake long enough from the boredom of running it now cause it will be so easy for you, lol!
man that looks nice! strong workThe sleeve for the tie rod flip finally came in today and I welded it in place. It was a fairly painless process. You drill the knuckle out with a 3/4" bit, weld the sleeve in, and grind the bottom flat. The flipped tie rod raised the TB about 1.5", previously would have been at 16" in the photo, the small change made a massive difference. Lastly, I adjusted the pinion down to 8.5° with the idea I'll lose the floaty feel. With any luck I'll stay vib free and not need a hub kit.
View attachment 186214View attachment 186215View attachment 186216
It feels good to have the jeep back on the ground. Now I just need to weld the bottom brackets for the AR in place, likely run new brake lines since I doubt the stock mounting location will work, and install the vacuum hose to replace the evap line once it arrives.
Thanks, I'm really happy with the results. Anyone with access to welder, grinder, and a drill can do it. Using the sleeve it's a fairly cheap, $30 with shipping, upgrade to do.man that looks nice! strong work
MUG root beer used to be my favorite, they dont make it like they used to though.I'm fond of Stewart's. But there again, only because it works with my particular like of the balance of sweet versus medicinal. A&W is far too sweet but the "root beer" flavor is good. If they could back down the sweet level some, it would be more tolerable to me. Stewart's has a nice balance between the root beer flavor, level of sweetness, and not too medicinal. The only thing that matters is if you like it, not whether I do.
When I was a kid mug was the only soda I would drink.MUG root beer used to be my favorite, they dont make it like they used to though.
I dont drink it at all actually, I hate carbonation in drinks. That specifically was the only one that I liked.When I was a kid mug was the only soda I would drink.
Dont drink soda no more tho, fructose is toxic in high concentrations, that and the benzene they add as an antimicrobial preservative is a carcinogen.
I test drove the jeep earlier. Up to 80mph, the max I went, there are no vibrations.
That said the cleaner way to do it would be to get a knuckle reemed for the flip.
I forgot about those, I fixed the post above.Don't forget the $60 for the sway bar mounts.
I’m not entirely sure how blaine does his but he sent me a flip ready knuckle in exchange for my old knuckle and a small fee.I test drove the jeep earlier. Up to 80mph, the max I went, there are no vibrations.
*and $60 in sway bar raisers.
That is how he does it.I’m not entirely sure how blaine does his but he sent me a flip ready knuckle in exchange for my old knuckle and a small fee.
And it isn't that I want or need your old knuckle. I just do the exchange so folks don't have to put the rig down waiting for me to get done and ship it back. This way, you can do the swap in a couple of hours.I’m not entirely sure how blaine does his but he sent me a flip ready knuckle in exchange for my old knuckle and a small fee.
I figured the old knuckle was for the next guy who wants to do the flip. Really appreciate the way you do that especially for us daily drivers. I should have the knuckle on the way to you by Saturday. Thanks for everything you do for the community!And it isn't that I want or need your old knuckle. I just do the exchange so folks don't have to put the rig down waiting for me to get done and ship it back. This way, you can do the swap in a couple of hours.
But, if you don't send me your old knuckle, you're fucking the next guy and when I run out, I'll have to decide to charge a stupid high core charge or quit doing it. I'd almost rather quit than deal with the core charge.
I have literally charged someone a 200 dollar core charge because they seemed a bit flaky. 4 months later they wanted it back. I don't even know who you are after that length of time passes much less why I owe you 200 dollars.
Not much magic involved, just patience and trial and error. One thing to be very aware of is the link end must not be able to be pushed under the frame. It is common to suck up a rock with a rear tire and have it cycle around and tear shit up. You don't want the arm to be able to be bent inward and shove the rod end under the frame.I had some time over the weekend to look at the rear antirock and cycle the suspension. I am extremely grateful that @mvigo drove over Saturday morning so I could take a look at what @mrblaine did to his jeep and also lent a helping hand to figure out mine. Before he arrived I was thinking I'd need a 1/2" spacer and new wheel studs to clear.
After bending the Antirock arms a bit more so the Heim barely clears the frame while cycling and adding 1/4" worth of washers to the wheels to act as temporary spacers the link cleared the tire on full articulation.
All I can say is @mrblaine is a magician (wizard). @mvigo and I have, more or less, identical setups in terms of tire size, lift height, midarm, wheel backspacing, etc but Blaine was able to make his work with less bend on the arms and no spacers.
Once the spacers come in I'll do a final test before burning in the mounts.
I remember you mentioning that earlier and made sure at full droop the Heim does not go below the frame rail.Not much magic involved, just patience and trial and error. One thing to be very aware of is the link end must not be able to be pushed under the frame. It is common to suck up a rock with a rear tire and have it cycle around and tear shit up. You don't want the arm to be able to be bent inward and shove the rod end under the frame.
all to familiar mine rolled up between the shock and tire and bent the shaft.
