Right!!! All I need now is for someone (not it) to get a ready welder and we can be doing outboards out on the trail. @Midnight LJR come on man.Dude that’s cool!
wouldn't it be more bombproof if the pressure switch was between the clutch and the relay? Asking for a friend.
My arb got stuck on once and I had to manually cut the power but it was actually the pressure switch that failed. At least that's the part ARB sent me and it worked fine ever since.If the replay sticks and the compressor keeps running the fuse will pop I'd hope. I guess you could put the pressure switch inline but I'm not sure there is a good reason to do it that way. How many times have you had a relay stick? I've had them go bad and not work but never stick.
I was reading somewhere that they recommended changing the oil on the york once a year. Does that sound right? Would you just suck up what you can then fill it back up or would it require removing the york?
It seems to me like that's a strange service interval based on the fact that yorks are used as A/C units....
Sound like if you get your rig back together for Moab you can be the mobile shop.Different oil and different usage. In the A/C system it is sealed and the oil used is different.
In this capacity you are sucking in dirty air that even though filtered still lets in dirt.
Dude I have a Ready Welder and a Premier Power Welder to power it with so we can fix just ABOUT anything.
There’s no combustion process gases entering the crankcase and it uses oil. Just keep adding as needed.I was reading somewhere that they recommended changing the oil on the york once a year. Does that sound right? Would you just suck up what you can then fill it back up or would it require removing the york?
Good to know. Thanks. How often do you check up on it?There’s no combustion process gases entering the crankcase and it uses oil. Just keep adding as needed.
Annually, I check mine every spring.Good to know. Thanks. How often do you check up on it?
So for servicing do you remove the York and drain the fluid out or can you just suck it out with an electric, or hand, pump and add fluid back in? The idea of removing the york yearly doesn't seem fun due to the fact the alternator needs to come out first. If it needs to be done so be it but figured I'd ask.
Not itRight!!! All I need now is for someone (not it) to get a ready welder and we can be doing outboards out on the trail. @Midnight LJR come on man.
Not sure yet. I may buy a small box for it and use it as a portable compressor for other vehicles but honestly, I haven't given it much thought. Do you need one?You gonna sell your ARB compressor?
I was thinking about buying one I could hard mount in the abs tray under the hood. I ran out of co2 yesterday and only got 3 out of 4 tires aired back up. Irritated me! I have a portable one in a bag, but it is with all our RV stuff. It would be nice to have a permanent backup solution, but then again you may want the same option if your york went belly up.Not sure yet. I may buy a small box for it and use it as a portable compressor for other vehicles but honestly, I haven't given it much thought. Do you need one?
Before the next run, whenever that may be, or if you're in my area, remind me. If I haven't found a good use for it it's yours.I was thinking about buying one I could hard mount in the abs tray under the hood. I ran out of co2 yesterday and only got 3 out of 4 tires aired back up. Irritated me! I have a portable one in a bag, but it is with all our RV stuff. It would be nice to have a permanent backup solution, but then again you may want the same option if your york went belly up.
Good thing I have a hand throttle. I'll give it another test later tonight and see how much it decreases the time.Next time you try to air up your tires or run a air tool rev your engine up to about 1,800 RPMS as that will increase the output of the compressor.
I had a moment to myself so I ran out and did another test at around 1,800. It filled up this time just under 50 seconds. Which is a 14 second improvement over idle.Next time you try to air up your tires or run a air tool rev your engine up to about 1,800 RPMS as that will increase the output of the compressor.
