Close, almost nailed it. I will tell you that the bolt pattern is US Standard 4.75" x 7.00".AT pan skid?
That makes me think a winch plate for 9.0rcClose, almost nailed it. I will tell you that the bolt pattern is US Standard 4.75" x 7.00".
4.75 x 7.00 inches is the US standard license plate bolt pattern.Wait!
4-75x10 it a license plate bolt patern
Which is what you said and my dyslexia butchered after looking at winch bolt patens.....4.75 x 7.00 inches is the US standard license plate bolt pattern.
I like the terminals. Can you show the other side
Well thought out and looks clean, Nice Work !View attachment 239172View attachment 239173
Mounts in the hole in the middle of this. Black dot gets drilled to allow passage of the wires into the tail gate over to the contacts which will drive the license plate lights on either side of the plate and the reverse light above the license plate. The plate covers the cut in the swing down cover which hides the wiring. The hole above the terminals is for the spring plunger on the outside that stops it from rotating off of the socket cap screws. I have countersunk hole magnets to hold the plate door shut and I have yet to build the release lever to push them loose to allow the door to flip down.
