Am I okay to jack up the front end by the axle housing?
GregBelleville
Southern California
I'm trying to raise my front end to put on Jack stacks so I can remove both front wheels and change my gear oil. Jacking under the pumpkin only raised the driver side.
Am I ok to jack up the passenger side using the able housing as pictured? If not, any suggestions on a better jack point to get the present side up?
I try to use the pumpkin but I doubt you will harm anything using the tube
Only thing to watch out for is the jack can slide down the axle tube if you tilt it very far.
Reactions: AaronPaul
I question that myself and try to remember.....the same amount of weight is still on the axle when its on the ground. Aint it?
Anyone know how fast a fly is going in your car? And if he flys backward how is that calculated?
Who’s idea was it to drink cow milk?
I really wanna know.
Reactions: P man
You should ask AndyG. He has a thread where you can do just that...
Reactions: AndyG
